required_alias
Feb 28, 2023Guide
R7000
Should be easy. I was sent a new Internet modem by my ISP. Since then, I can't log in to my 50 network. when I type in 192.168.1.x in my browser, I get the ISP home page. How do I access my route...
khustabak
Mar 16, 2023Aspirant
Everytime I have a power outage or some form of issue where the router loses power, the internet speed throttles down from lets say 235 download to 66 download. In order to fix this, I need to go on my laptop, go into the QoS setting in my routerlogin.net and do a manual speed test. Somehow by doing this, the speed "unlocks" and is back to normal.
I have the Nighthawk R7000 with Netgear CM400 modem, with Xfinity.
Any help appreciated!
michaelkenward
Mar 16, 2023Guru - Experienced User
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. The firmware version installed, for example.
