Teamsters630
Mar 09, 2023Follower
R7000
Hi, I’m very new to this. I’m having issues updating my firmware. It’s sending my a link to router login.net
However, it won’t download. It just says “attempting to connect to Netgear server”
Then it just times out
I’ve tried to download the file on my iPad but when I try to use it, it says use the correct format *.chk
i don’t understand it
pleas Help
1 Reply
I don't follow this. How are you going about the update?
The safest and most reliable approach is a manual update.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
