spadude60
May 12, 2023Aspirant
R7000
I have recently obtained an issue with my router where I couldn't connect due to an internet issue. I have now reconnected with the internet and now my router is acting weird. This is a dual band and ...
- May 13, 2023
the R7000 has smart connect meaning it combines the 2.4ghz/5ghz bands.
Do you have that enabled? If so, the bands won't show up separately. Might be worth checking.
May 12, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
- spadude60May 12, 2023AspirantThanks Furrye38
I did the restart the way you said and put those settings at what you suggested. And now just the 2.4Ghz works. Still can't get the 5Ghz to even show up to connect to. There are no firmware updates and haven't had one in quite a while. So not sure what I should do. Just wondering if second band just is fried or what. We have had this router for approx 7 years. Have never really ever had a problem with it.
Any other suggestions?
