roguelex
Sep 06, 2023Aspirant
R7000
need helpo setting up for gaming, i can not get speed i have whicj is 1.2G and connecting to ps4.ive tried qos off and still only getting slow speeds. latest firmware also
roguelex
So I’m running v1.0.11.136_10.2.120
The 1.2g is what I get at the modem which is higher than advertised I’m actually around 1.4g.
The Modem/router is Xfinity XB8-T. Yes it’s modem/router. With 3 1G ports and 1. 2G port. So I recently connected the R7000 as a bridged device. I’m getting now around 300mbps max. But now I can’t log into admin. Going to try ping so that I can get ip address due to fact that it changed.
roguelex
And it’s Bridged thru 5G
- KitsapSep 06, 2023Master
What devices are you gaming on and how are they connected to the internet? Wi-Fi or Ethernet?
- michaelkenwardSep 07, 2023Guru - Experienced User
roguelex wrote:
And it’s Bridged thru 5GI assume that this is a wireless bridge. The bridge word means different things in different contexts.(see above)
And 5G is 5 GHz?
Is that working as expected?
If you don't want to bridge the modem, any possibility of doing AP mode on the R7000 wired to the modem/router? That should be more reliable and faster.
