JASIV
Apr 14, 2024Aspirant
R7000
Firmware Version V1.0.11.136_10.2.120 Windows 11 pro Router shows not connected when the connection is good
Apr 14, 2024Guru - Experienced User
Has a power OFF of the Hitron EN2551 modem and the R7000 for 1 minute then back ON with the Hitron modem first then R series router been performed?
Be sure your using good quality LAN cable between the modem and router. CAT6 is recommended.
Swap cabling out and test.
Not connected is an indication of bad cable or ISP modem not giving too service to the router.
JASIV wrote:
Firmware Version
V1.0.11.136_10.2.120Windows 11 pro
