Pcahill1047
Jul 23, 2024Follower
R7000
My router was reset and now I have no internet or access. This is hour 14 I’m working on it with no solution. Someone I spent over an hour saying they were NG and taking credit card for $120 was usele...
Jul 23, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is the Internet LED on the router WHITE or AMBER?
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed?
