Ronsfour
Jul 29, 2024Aspirant
R7000
I picked up my router to see the model number and now it's not working. I've tried to unplug and plug it back in and no luck. I hit the factory reset and no luck. I noticed the is a locked light on th...
- Jul 29, 2024
Is the Power and internet LED ON?
What colors are the power and Internet LED?What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn off router and computers. Unplug the router from the wall outlet for 1 minute then plug back in.
Turn on computers and rest of network.Press the reset button for 15 seconds then release.
Jul 29, 2024Guru - Experienced User
- RonsfourJul 29, 2024AspirantThe power light is on, white and solid. The light next to it that looks to be the internet light(unsure if that's what it is) is on, white and flashing.
- FURRYe38Jul 29, 2024Guru - Experienced User
And the 2.4 and 5Ghz WiFi LEDs are ON or OFF?
- RonsfourJul 29, 2024AspirantGoing through your restart steps worked. Thank you very much for the info and your time. I'm up and running again. Thanks again, it is veryuch appreciated... 👍👍
