aclovasz
Oct 14, 2024Follower
R7000
I have several devices connected to the router and they are working. All of a sudden my iphone can't find the router. Could the router be ignoring the iphone and if so how do I fix it. There are other iphones working fine.
if everything is working but the one device, its usually an issue with the device. the router can't stop broadcasting for just one device.
Can't find in what way? Doesn't see the SSID? Refuses to login?
Are these using WiFi?
As plemans says, when one gadget falls over, it usually points to that as the source of the problem.
Your R7000 doesn't care the device you throw at it.
Tell the iPhone to forget that it ever knew about the router and reintroduce it to the router.
Just another user with time on their hands.
