dcook7312
Nov 11, 2017Tutor
R70000 Google Fiber - DNS OpenDNS
I"m trying to get FamilyShield Open DNS numbers or regualr OPEN DNS numbers working at my home for filtering reasons for my family. I'v tried setting up the DNS numbers in the Google Fiber Network Bo...
- Nov 11, 2017Just flip the switch on the R7000 to router mode. Make sure to connect all devices through the R7000. Don't connect anything else other than the R7000 to the GFNB.
TheEther
Nov 11, 2017Guru
dcook7312
Nov 11, 2017Tutor
Thanks. I think that did it. I didn't realize Netgear had Open DNS and Circle built in. I used the built in version of Open DNS and I think I'm up and running. I checked the Open DNS test page and it worked. Thanks again. Let me know if I missed anything or if there are real problems with double NAT I'll encounter.
- dcook7312Nov 20, 2017Tutor
This has been working well since I set it up except when I try to VPN into my office to do work on the office network. I was reading on double NAT and it mentioned that VPN and gaming sometime make it difficult. I've read some about port forwarding and DMZ but am not sure I know how to set those up or would that even help. Any suggestions?
