Timgf
Nov 16, 2020Aspirant
R7000in bridge mode
I am using an R7000 in bridge mode for extended wi-fi (with an R8000 as the primary router). Does anyone know if the wired ports are still live on the 7000 or does bridge mode disable them ? (Yes - I know I could test, but it’s in an inaccessible location and it would help to know beforehand)
> I am using an R7000 in bridge mode for extended wi-fi [...]
What, exactly, does "bridge mode" mean to you in this context? How
is the R7000 connected to the "primary router" LAN? (Hint: If a device
has different types of Ethernet ports, then "connected to device" is not
enough detail.)Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Set Up the Router as
a WiFi Access Point" and "Set Up the Router in Bridge Mode". Are you
doing one of those? (Which, or what else?)> [...] Does anyone know if the wired ports are still live on the 7000
> or does bridge mode disable them ? [...]As Netgear uses the term, "in Bridge Mode", the LAN Ethernet ports
are the _only_ things to which you can connect client devices. If,
instead, you've configured the R7000 as a wireless access point, then
you should be able to connect client devices to it wirelessly or using
its LAN Ethernet ports.- TimgfAspirantThank you. I guess I’m a bit hazy on the terminology. I switched recently from a DSL to a microwave ISP. This is quite a large house so I put in an R8000 and ran a wire from the basement to the attic. The R 8000 wi - fi is in the basement and the R7000 is now in the attic providing wi-fi (with different names) for the upper part of the house. I thought this was called bridge mode but I may be using the wrong name. The R8000 is acting as the router and I was trying to establish if I can use the ports on the R7000 or if in this mode it is suitable for wi-fi only. I think you have answered that the ports are still live and can be used.
- TimgfAspirantOh. The Ethernet wire runs from one of the ports on the R8000 to the WAN port on the R7000
