mzoomers's avatar
mzoomers
Follower
Dec 14, 2018
R7000P - 5Ghz channel broken - support not answering
Unfortunately, the 5Ghz channel of my R7000P is not working. I've tried everything to get it to work, from changing WiFi configuration to installing different firmware versions, but without luck.  ...
  • DarrenM's avatar
    Dec 20, 2018
    Hello mzoomers
    I have escalated your case for someone to contact you about the issue.
    DarrenM
