ADIT1's avatar
ADIT1
Follower
Jan 06, 2022
R7000P - Can't Disable Remote Management
Firmware: V1.3.3.142_10.1.75
Cannot disable remote mgmt under Advanced/Advanced Setup/Web Services Management
I uncheck the Turn on Remote Management box and click Apply.  It returns checked.
Also cannot change the port # or the IP Address selections (Everyone/Range/Only This Computer).  I can toggle the HTTPS requirement box.
Only using this as a router.  WIFI is disabled.
I upgraded to the latest firmware (above) because of stability issues.  Defaulted it and manually reconfigured after the upgrade.  Not sure if I enabled remote mgmt after the upgrade, but need it disabled for a PCI scan now.
Anyone else seeing this?
  • FURRYe38's avatar
    Try a different browser?
    Is the Nighthawk app connected to the router?
    • adit's avatar
      adit
      Mentor
      Factory default after firmware upgrade - Yes.
      Tried Chrome/FF/Edge/IE11.  Didn't make any difference.  None allowed the change.
      Not onsite so the Nighthawk app is useless.
      Thanks
