fire888
Jul 16, 2021Guide
R7000P - network disconnected
Hi, about a month ago, my router R7000P was giving me weird symtomps. Whenever my laptop connected to 5G, it would make ALL my other devices that connect to 5G disconnected (or maybe I should say...
Jul 17, 2021Guru - Experienced User
try installing version 1.3.0.20 of the firmware. then do the factory reset and install. Don't install from a backup configuration.
And then disable auto-updates.
This version was the version before netgear armor. I've seen some instances of r7000ps that struggled with armor.
That's where I'd start
fire888
Jul 17, 2021Guide
If it's about the armor, I have disabled it since after reset.
- plemansJul 17, 2021Guru - Experienced User
disabling armor doesn't remove it from the firmware. Armor is built into the firmware on the newer versions of firmware. Its why I recommend downgrading to the versions prior
- fire888Jul 20, 2021Guide
I have tried it in these few day, and nope, downgrading the firmware didnt help either
oh yeah, finally I can catch on what it was doing when all network down.
I attached the video here.
I suspected it was restarting itself ? because like I said, when it finally connected again, and I checked the logs, the logs always cleared out and starting from the time when it connected again
edited : cannot attached a video here
so I'll just attached the screenshot from the video.
on the screenshot only 4 lights on (orange on left and right and 2 whites on the middle)
after a few secs, there would only 2 lights on (orange on the left and 1 white on the right - couldnt post it here as only 1 picture allowed), before finally a few secs more, some of other lights would start to light on one by one until all the lights turn on again.
- plemansJul 21, 2021Guru - Experienced User
After the downgrade, you did a factory reset and new install? (didn't use a backup configuration?)
have you tried a different power supply? it needs to have the exact same polarity and voltage but can have higher amperage.
