Elrahir
Feb 26, 2019Aspirant
R7000P - Slow WiFi - Only getting 54Mbit on 2.4/5GHz
Hi,
I´m having a really annoying issue with my R7000P router (FW V1.3.1.44_10.1.23). I´m only getting 54Mbit wireless link speed (PHY) on either the 2.4 or 5GHz. Regardless how close I am. This go...
- Feb 26, 2019
manual says here: ADVANCED > Setup > QoS Setup > WMM.
duckware
Feb 26, 2019Prodigy
Verify that "WMM" is ON for both bands.
duckware
Feb 26, 2019Prodigy
- ElrahirFeb 26, 2019AspirantOhhh wow thanks! That did the trick! I thought that was supposed to be off just like QoS. I belive I've read that somewhere before..
Care to explain what WMM does and why it limits the speed when off?
I read through your excellent webpage today btw, very interesting and useful.- duckwareFeb 26, 2019Prodigy
I don't know the technical reason why. All I can find over and over is that WMM is required for 'high throughput' speeds. The tip off that WMM is off is a PHY speed limited to 54 Mbps.
You would think Netgear would add a very simple warning on the WMM web page that turning WMM off limits speeds to 54 Mbps -- and that would make a LOT of common sense (and then that explains why Netgear does not do this).
