fire888
Sep 19, 2021Guide
R7000P - Wifi 5G With GPD Win Max
Hi, I have a problem with my R7000P. that is when my gpd win max connecting to the 5G wifi, in about less than 1 minute, the 5G wifi would down for a few seconds, and would go back up again (ye...
fire888
Sep 19, 2021Guide
Sorry I couldnt edit the 1st post.
Just want to add more infoso that it's more lcear,
this only happened with the gpd win max. All other 5G devices could connect just fine.
But when the gpd win max connecting, in less than a minute, the 5G wifi would down for a little while (like 5-20 secs), and then it would function again like normal.
My gpd win max's use have lots of turns off/turns on, so this would happened alot if I connecting to the 5G network directly on r7000p
oh and I have tried to see the router's log, and there's nothing about this. Only that after the 5G network connecting again, there're some logs about dhcp about some devices connecting to the 5G (because they just connected again after the 5G went down and up again).
