ratkutti
May 17, 2018Aspirant
R7000P 5Ghz Unusable
Initially after purchasing the device on 21st April 2018, after 5 days QoS made the whole device unusable, got connected but Internet won't work. Also traffic meter won't work. I reseted & didn't en...
- May 26, 2018
Issue came up again, emailed support and as per their advice downgraded the firmware; with the latest firmware 5Ghz used to work few hours before being unresponsive; with the old ones it out right refuses to connect! Called and finally got a RMA authorized, going in later today to the local service center to get the replacement, which thankfully they have in stock.
ratkutti
May 20, 2018Aspirant
Emailed support, as I had issues even after downgrading firmware. I guess I found out a solution, all I did was to put 5Ghz in the highest available 48 channel and its now one full day on the latest firmware sans any issue!
ratkutti
May 26, 2018Aspirant
