Creatium
May 30, 2018Guide
R7000P 5GHz wifi speed going down after a few days
Hi!
I am having issues with my rather newly purchased R7000P router. I have both 2Ghz and 5Ghz wifi enabled. The problem is that at first everything works fine, but after a few days of working ...
- Feb 03, 2019
So my router just stopped working. Red power light, neither simple or hard reset works. I am returning it and probably going with TP-Link next time.
Case closed.
Creatium
Jun 13, 2018Guide
So I think I solved my problem. I have disabled my internet-over-power adapter 5Ghz Wifi and speeds on main router are still as high as should be. I don't get it. Channels where different, so they shouldn't have been interfering with each other.
Anyway, it's been a week now and everything seems to be ok.
Blanca_O
Jun 13, 2018NETGEAR Employee Retired
Hi Creatium,
Thank you for your feedback. Glad that it's working now.
Blanca
Community Team
