Creatium
May 30, 2018Guide
R7000P 5GHz wifi speed going down after a few days
Hi!
I am having issues with my rather newly purchased R7000P router. I have both 2Ghz and 5Ghz wifi enabled. The problem is that at first everything works fine, but after a few days of working ...
- Feb 03, 2019
So my router just stopped working. Red power light, neither simple or hard reset works. I am returning it and probably going with TP-Link next time.
Case closed.
Creatium
Jun 16, 2018Guide
I am very confused. This morning speeds are up to what they should be. All the same devices are connected, no settings changed.
- Blanca_OJun 17, 2018NETGEAR Employee Retired
Hi Creatium,
Thank you for the update. Kindly observe the connection for few more days.
Blanca
Community Team- Blanca_OJun 24, 2018NETGEAR Employee Retired
Hi Creatium,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team- CreatiumJun 24, 2018Guide
I had vacation last week, so was unable to keep an eye on my wifi status. However I didn't notice any changes after I came back, so far it works. I will keep on testing speed on wifi every day and see if anything happens.
