Creatium
May 30, 2018Guide
R7000P 5GHz wifi speed going down after a few days
Hi!
I am having issues with my rather newly purchased R7000P router. I have both 2Ghz and 5Ghz wifi enabled. The problem is that at first everything works fine, but after a few days of working ...
- Feb 03, 2019
So my router just stopped working. Red power light, neither simple or hard reset works. I am returning it and probably going with TP-Link next time.
Case closed.
Creatium
Sep 01, 2018Guide
Updated to the latest firmware and problem still exists.
Going for warranty replacement I guess.
shadowsports
Sep 02, 2018Hero
Greetings,
Does the bandwidth flucuation occur across both wired and wireless interfaces, or just wireless?
Have you reset the device, set up from scratch and tested speeds?
Just reset, make no changes and test using defaults.
Settings you'll want to avoid:
QoS
Traffic Meter
Smart Connect - At least during troubleshooting.
