Creatium
May 30, 2018Guide
R7000P 5GHz wifi speed going down after a few days
Hi!
I am having issues with my rather newly purchased R7000P router. I have both 2Ghz and 5Ghz wifi enabled. The problem is that at first everything works fine, but after a few days of working ...
- Feb 03, 2019
So my router just stopped working. Red power light, neither simple or hard reset works. I am returning it and probably going with TP-Link next time.
Case closed.
Creatium
Jan 12, 2019Guide
Let me answer anyway. No, I have not found any solutions, except to stop using the devices I am using. And that truly is not a solution to, probably, a software problem.
Tried contacting Netgear support, but no answer. Am really disappointed.
Lozza6
Jan 12, 2019Aspirant
Hi, my 2nd post was wrong but my first post did apply to this thread. I have the same problem as you.
The deleted post was responding to a 2nd thread here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/WiFi-speed-drops-every-few-days/m-p/1689322
Which doesn't solve the problem but there is a simple fix.
Log into the router then go to 'wireless' then click 'apply' at the top. This seems to restart just the WiFi portion of the router and then I got full WiFi speeds again. The speeds then slow down again over a few days so it's definitely not a solution, but at least it's a temporary fix and saves you having to restart the whole router.
Hope at least in the interim at least that helps you a bit. I'm going to keep an eye on it, but if there isn't a proper fix, I'm gonna return it under warranty.
Good luck!
Good luck!
- CreatiumJan 12, 2019Guide
Thank you, that is really a better and faster option than restarting the router.
