Creatium
May 30, 2018Guide
R7000P 5GHz wifi speed going down after a few days
Hi!
I am having issues with my rather newly purchased R7000P router. I have both 2Ghz and 5Ghz wifi enabled. The problem is that at first everything works fine, but after a few days of working ...
- Feb 03, 2019
So my router just stopped working. Red power light, neither simple or hard reset works. I am returning it and probably going with TP-Link next time.
Case closed.
Lozza6
Jan 12, 2019Aspirant
Hi, my 2nd post was wrong but my first post did apply to this thread. I have the same problem as you.
The deleted post was responding to a 2nd thread here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/WiFi-speed-drops-every-few-days/m-p/1689322
Which doesn't solve the problem but there is a simple fix.
Log into the router then go to 'wireless' then click 'apply' at the top. This seems to restart just the WiFi portion of the router and then I got full WiFi speeds again. The speeds then slow down again over a few days so it's definitely not a solution, but at least it's a temporary fix and saves you having to restart the whole router.
Hope at least in the interim at least that helps you a bit. I'm going to keep an eye on it, but if there isn't a proper fix, I'm gonna return it under warranty.
Good luck!
Good luck!
Creatium
Jan 12, 2019Guide
Thank you, that is really a better and faster option than restarting the router.
