T-Tarkus
Aug 17, 2017Tutor
R7000P (AC2300 Smart WIFI Router) Slows Down LAN
I suppose I made a bit of an error of purchasing everything at once and also changing my ISP speed as well but I have been attempting to diagnose a recurring problem for a couple of weeks now. Fi...
- Aug 25, 2017
Thanks to those who attempted assistance. The solution turned out to be returning the Netgear router and purchasing an Asus 2400 instead.
T-Tarkus
Aug 18, 2017Tutor
> You seem to have tried lots of things. Did they include searching this forum for similar messages?
My fading memory suggests that this one might prove helpful:
>>>> slow speed qos R7000P <<<<
The very first thing I did was go through a variety of searched topics such as "slow speed R7000P", "slow LAN speed R7000P", "inconsistent LAN speeds R7000P", and a few others. I am now retired but I used to be a NSTS CSE so this isn't exactly my first rodeo so trust me I was hoping there would be some silver bullet.
> Sadly, many problems prove difficult to diagnose and there is rarely a single fix.
Yes indeed which is why I am hoping that those with more experience with this router might have an idea why when I direct connect to the modem I get around 98% efficiency but when I connect to the router, in this case only with the LAN connection just to see if I can get an instance of full speed, the speed efficiency drops to about 35%. All factors such as "oh you must have a virus" would affect the direct connect, firewalls and anti-virus programs would affect the direct connect, cabling has been switched such that the Modem to Router link has been configured into Modem to PC so it isn't the cable since in ALL scenarios the direct connection essentially provides 250 out of 250 Mbps speed.
I speak from a past history of 'debug sessions' where unlike home ISP connections it was required to determine if the problem was on the other side of the demarcation side so yes I do realize this is hard but in this situation I can be assured of two specific certainties; first the WAN demarcation side is providing exactly what is contracted as I can run direct connect at 250 Mbps for days on end so there is no purpose in investigating if the ISP is the problem, second, the moment the PC is reconnected to the router the speed goes to **bleep** so the issue not that the "R7000P might be the cause" but rather that the "R7000P is the cause." This is why I added the PC configuration because maybe the router hates the new AMD Ryzen processors, or the ASUS X370 Pro motherboards, (can't really imagine the Nighthawk hates Windows 10 or Netgear would be out of business). That said this system is rather current for example the Ryzen 7 1700 is currently rated as one of the top 5 home computer processors out there and no I am not bragging but rather wonder if there is a large enough sample out there of people with what is a reasonably advanced PC configuration and also a R7000P router?
So while I appreciate your candor I am rather hoping that someone will say "I had/have the same problem and I fixed it/couldn't fix it".
I mean worst case scenario if I have a monster download just wait until no one in the house needs the network and direct connect but that is such an inelegant solution.
michaelkenward
Aug 18, 2017Guru - Experienced User
I am surprised that your years of "debug sessions" haven't taught you that Netgear does not care about your operating system and certainly not your CPU. Indeed, it doesn't know about Netgear unless you try to install its software, the desktop genie, for example.
The only bit of your PC that matters in this context is the LAN connection and its drivers. If this is a self-built PC, then Windows 10 is likely to have slapped generic LAN drivers on the installation rather than those written by the chipset makers. Then again, that would also affect the direct connection to the modem, so I think we can rule that out.
Forgive me for not going into your lengthy reply in detail, but your response adds nothing in the way of information and doesn't show if you played around with the QoS settings on your router.
That was the point of my search. People have found that these settings can interfere with LAN speed.
Forget about the R7000P. The issue you see affects various models. So widen your search.
PS If it matters, and I don't see why it should, I am also of the retirement generation, although I still manage to sell a few words to while away some of the hours that I am not wasting here.
