CaliforniaQuick
Jan 02, 2020Aspirant
R7000P and Frontier FIOS 500/500 slowness
`So I've had the R7000P (AC2300) for a while now with Frontier FIOS 150/150 here in Southern California, and recently upgraded to 500/500. I'm running straight ethernet directly from the ONT to the W...
- Jan 03, 2020
Version 1.3.1.44 was the version that supported netgear armor rollout.
I'd actually try the version prior to this as many device had issues with the initial rollout of armor.
CaliforniaQuick
Jan 03, 2020Aspirant
So, I downgraded to Firmware Version V1.3.1.26_10.1.3 and here are the results:
speedtest from router: 350 DL / 350 UL
speedtest from Macbook connected via Wifi: 225 DL / 500 UL
So, that's definitely better but Im still curious why Im not pulling closer to 500 DL at the router.
Jan 04, 2020Guru - Experienced User
After the downgrade, did you factory reset? A full reset? not just a reboot.
Reason I ask is certain features disable ctf/nat acceleration. when you reset and reconfigure, what all features are you setting up? Or how are you setting it up?
Just trying to figure out because it sounds like ctf/nat acceleration is disabled if you're peaking at those speeds. Smallnetbuilder put its ctf score at roughly 33%. Meaning when ctf is disabled, you see a reduction of 33% in speeds.
- CaliforniaQuickJan 04, 2020Aspirant
Performed a rull router reset. Same speedtest results.
I dont have anything configured differently than the defaults ...except for SSID name and passowrd. IPv6 and QOS disabled.
- plemansJan 04, 2020Guru - Experienced User
What model ONT do you have?
Alcatel 0-211M-H
