roger_h
Jun 04, 2019Aspirant
r7000p as access point has fixed ip address by default that prevents login and
The r7000p manual states that a static is set on the lan by default. The default in my case was the same as the router I amj connected to. This prevents access to the r7000p configured as an access p...
- Jun 04, 2019
roger_h wrote:The r7000p manual states that a static is set on the lan by default.
This is correct.
roger_h wrote:The default in my case was the same as the router I am connected to. This prevents access to the r7000p configured as an access point from being reached via an IP address.
This is wrong! The fine documentation Nighthawk AC2300 Smart WiFi Router User Manual, p.64, "Use the Router as a WiFi Access Point" does say:
You can set up the router to run as an access point (AP) on the same local network as another router.
To set up the router as an AP:- Use an Ethernet cable to connect the Internet port of this router to a LAN port in the other router.
- Launch a web browser from a computer or mobile device that is connected to the network.
- Enter http://www.routerlogin.net.
A login window opens. - Enter the router user name and password.
Network Settings
64
The user name is admin. The default password is password. The user name and password are
case-sensitive.
The BASIC Home page displays. - Select ADVANCED > Advanced Setup > Router/ AP / Bridge Mode.
The Router / AP / Bridge Mode page displays
The problem you state does not exist - it was created by the admin.
roger_h wrote:Do not tell me I have to reset the r7000p and start over. Been there and done that.
Netgear needs to fix the setup to allow entering the gateway address and letting the router assign an IP. The interface should allow this and doesn't. It needs to be fixed.
Hm, don't think you have to reset ... When you go to Advanced -> Advanced Setup -> Wireless AP where you can tick the (x) Enable AP mode, and scroll down ... there should be everything (e.g. the choice for selecting DHCP client or a static IP) you are behind. It's not a part of the Advanced -> Advanced Setup -> LAN setup, indeed.
Here the UI as it looks in the "new" design where we set the mode to AP - must be different from your R7000P - but the functionality is the same:
Seriously, the time we spend to write here is much more than factory reset a R7000P and re-configure the hand full of data it from scratch as an AP - and doing it right away the way you want it ..... when I have it right the R7000P does handle it that way -> I’m setting up my NETGEAR router for the first time, how do I set it to Access Point (AP) mode? ... the biggest problem is that the WAN/Internet port must be used ... obvious to avoid the duplicated default LAN IP.
roger_h wrote:Only routerlogin.xxx doesn't and I prefer using an IP. If I had 2 AP's attached routerlogin wouldn't work anyway.
The routerlogin.xxx is captured on the AP, and works while being connected to that device wireless or Ethernet - of course it works with one, two, or hundreds of devices on a LAN - because it applies to a small subset of devices only. Very similar the mywifiext.xxx when working with Netgear extenders. This does connect you to the "next hop" device.
roger_h wrote:To be honest the user interface is flaky.
It might not be intuitive. Consumer routers don't make good AP for experienced network admins anyway - to much user guidance like for duplicating wireless SSIDs and so on ... good for consumers, bad for us. But once more, this is not the problem here - the weak point is between chair and keyboard, sorry.
schumaku
Jun 04, 2019Guru - Experienced User
This is correct.
Network Settings
64
case-sensitive.
roger_h
Jun 07, 2019Aspirant
I noticed a lot of complaints about not being able to access the AP after setup with no clear
resolution. When it happened to me twice, I didn't relish going to the barn again in the rain.
The router address is 192.168.1.1 and the address in the r7000p was also 192.168.1.1
and except for not being able to access the AP it was working? No ip was assigned.
Occasionaly I could access the AP via routerlogin.net, I decided to change the lan ip to 192.168.1.139 from 192.168.1.1 and after reboot I could access it using 192.168.1.139 but not from routerlogin.net and the AP was still working?
After my last post I thought that because the lan ip was no the same as the router , I should retry the AP setup. I did and this time it was assigned to 192.168.1.102 with gateway set to 192.168.1.1 the router ip. Now the AP is reachable from routerlogin.net and 192.168.1.102 as expected and the AP is working fine. So I'll accept the previous post as I obviously didn't set it up perfectly to begin with.
