YHawk87
Feb 21, 2021Follower
R7000P Bricked. Accepts TFTP from Serial Cable but Will Not Load Properly
R7000p bricked after a botched firmward update. I can access the CFE via serial cable through Putty. After nvram erase, the device accepts tftp and a transfer of the latest firmware "r7000p-v1.3...
DarrenM
Feb 25, 2021Sr. NETGEAR Moderator
You can check with support if the unit is still under warranty. But it may be bricked if the TFTP is not working.
DarrenM
