hajjy
May 23, 2023Aspirant
R7000P can't connect to network
So I chose to use a different internet provider and when I type in the username and the password it still doesn't connect. I've made sure its a PPPoE connection but it still won't work. I've factory ...
michaelkenward
May 24, 2023Guru - Experienced User
hajjy wrote:
So I chose to use a different internet provider....
You asked them how to set up your connection?
- hajjyMay 24, 2023AspirantYep, gave them a call and everything Ive done is correct. After trying the same thing for about 20 times… it has finally just connected and all is good. Thanks for replying to my post fellas !
- FURRYe38May 24, 2023Guru - Experienced User
Please give more details next time you post so we can help you better.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- michaelkenwardMay 24, 2023Guru - Experienced User
FURRYe38 wrote:
Please mark your thread as solved so others will know. 📡
Don't bother. That's not going to help anyone. We have no idea why hajjy had problems and how they fixed them.
The Solved flag is only useful when it offers other victims clues as to what they can do. Saying "I talked to the ISP" and "everything Ive done is correct" hardly qualifies".
