D1xon00
Jan 04, 2023Tutor
R7000P Conflicting WiFi
I have noticed ever since I started working from home on a laptop, that if both my phone (Samsung S8+) and the laptop (Lenovo ThinkPad w/ 10th gen i5), that after a random amount of time, or seemingl...
- Jan 04, 2023
You for sure can just try the update and see if it helps.
If you still have issues, then try the factory reset. Sometimes old settings can cause issues.
Jan 04, 2023Guru - Experienced User
what firmware is on the router?
What modem/gateway is it connected to ?
did you try a different dns provider?
D1xon00
Jan 04, 2023Tutor
Firmware is:
V1.3.2.134_10.1.66
I updated through the auto update feature.
The modem is a Motorolla MB8611, I have Xfinity as my ISP.
Sorry if that is not what you are asking.
DNS is set to automatic from ISP and is set to 75.75.75.75
with backup of 75.75.76.76
Networking is not my area of expertise so I don't go digging to change anything I don't need to. So please be patient if I don't understand the question.
