D1xon00's avatar
D1xon00
Tutor
Jan 04, 2023
R7000P Conflicting WiFi
I have noticed ever since I started working from home on a laptop, that if both my phone (Samsung S8+) and the laptop (Lenovo ThinkPad w/ 10th gen i5), that after a random amount of time, or seemingl...
  • plemans's avatar
    Jan 04, 2023
    You for sure can just try the update and see if it helps.
    If you still have issues, then try the factory reset. Sometimes old settings can cause issues.
