dav0dav0
Apr 13, 2021Guide
R7000P crashes with Readyshare usage
Nighthawk router running fine with 2.4 and 5GHz users. Hook up 2 TB USB drive (Western Digital, nothing exotic) formatted as NTFS (probably MBR, but not sure). Basic readyshare read/write with driv...
- Jul 16, 2022
Well, I don't want to jinx this, but I believe all the above issues have been resolved. I've been running for 5 days now with 100% functionality, no reboots, and a more responsive/reliable administrative app (NetGear's Genie on the PC).
The big change: doing a factory-reset on the router and manually reconfiguring it to my needs (i.e., not doing a backup/restore of settings).
Seems like something somewhere in the router's little mind had gotten corrupted, causing all kinds of confusion.. What may have caused this was its moving to a totally new network (when it was new, it was on one ISP...then it got moved to a new ISP without making any changes). Note that in during all my wild-goose chases I had updated the firmware, and the confusion persisted because the problem was buried somewhere in the configuration/settings data.
So the morals of my story are:
- When troubleshooting, start with a factory refresh and brand new settings
- When moving a router across networks, see #1
dav0dav0
Apr 14, 2021Guide
Looks like I've answered my own question via experimentation.
The USB port on the back says USB 2.0 and the manual advises "put slower devices like printers there".
This should be re-interpreted as "don't you dare to attach any disks there!!!"
Plugged the disk drive into the front panel USB 3.0 socket and it runs likea champ...24 hours straight (my script is copying a LOT of files) with no gliteches.
I suspect what's happening with the rear socket is this:
- USB 2.0 does good handshake with USB drive
- At some point (20 minutes of use?) the drive somehow overruns the speed or vocabulary of the USB 2.0 port
- At that point, the USB multiplexor chip in the router goes berserk and has tons of low-level error conditions
- Router CPU gets waaaaaay too busy servicing all those low-level error conditions which it can't really do anything about
- Router goes into life-support mode where it can't do anything new (just handle existing connections and streams), and doesn't have the time or code to log hardware errors.
The front socket has a different chip (and a different code-path), and doesn't get caught up with any of this...it just hums along dutifully.
- dav0dav0Apr 20, 2021Guide
Another update...
Did a full low-level disk check of the NTFS/MBR partition to make sure there weren't any corrupted entries. All good.I have been using the USB disk from the front port for a while now, and it's looking like there's another level of issue with this router's firmware.
When the router first connects to the disk, it spends a couple of minutes reading something from the disk. I'm going to assume it's the directory structure, to make accesses faster once everything is in memory.
But...it appears that after a few days (where I'm barely using the disk, but banging pretty hard on the WiFi) the router loses its mind, stops serving internet, won't let me log in to the administrative console, and eventually is doing nothing but blinking it's LEDs happily. Only slution is to reboot both it and my cable modem. I'm going to guess this is a memory leak, or some other resource constraint.
The perhaps interesting factoid is the disk holds about 1,250,000 files in 1.8 TB.
I'm fooling around with the configuration (e.g., disconnect ethernet ports, disconnect disk) to troubleshoot...but really, I'm flying blind.
As this same disk drive works fine in readyshare mode with a 10-year-old Netgear $40 WiFi router, it seems hard to believe that Netgear messed things up on this model.- dav0dav0Jul 03, 2022Guide
Still running with same configuration, tried various experiments to see what the issue was.Clearly, using the front USB port is way more likely to be successful over the long run than using the back one.
For whatever reason, the configuration got way more unstable after 9 months of only having to hard-reboot every 3 weeks or so... the Netgear "freezes" as described above were occurring more than daily. Noticed that the problem seemed to be triggered by windows clients (there are only two of them...every other device is a phone or tablet) coming out of sleep/hibernate mode. Also noticed that the USB hard disk spun up at random times for no particular reason (probably some sort of router housekeeping of Readyshare).
Here are the things that offered no improvement:
- Turning off WMM
- Turning off QOS
- Putting a powered USB hub between the router and the disk
- Swapping out the power supply
- Power cycling the router every night at 1 am (no usage for hours before or after), letting it cool off
Here's what made a BIG difference: turning off MU-MIMO and the ReadyShare DLNA Media server features (both very nicely hidden in the menu tree). Even with that noticed that the router was rebooting itself on a daily basis. Sometimes when a windows client came out of hibernation, sometimes when there hadn't been any user activity for hours.
To quote Miss Anne Elke, I have a theory! This router must run an enormous amount of software, given the time it takes to come back online after a boot, and how long it takes to log in as an administrator when the network is under load. Evidently, this issue is made much more significant when a USB disk is attached with a lot of files. My theory is that the ReadyShare Media Server features make the processing load much worse (it generates a SQLite database that can be 50 MB or more), and that MU-MIMO has to do a lot of work whenever it sees a new or returning client -- and too often, the router wraps itself around the axle and becomes unresponsive. Once you turn those features off, the daily reboots that still occur are relatively transparent (happening either when nobody is looking, or happening in a way that just makes the network less responsive for a minute or so) are, I believe, the result of the router successfully recovering when its backlog gets to be too big. (I'm being nice here: it's just as likely that the Netgear software has some sort of watchdog function that triggers a reboot when the processor hits a bug, a buffer overflow, an out of memory situation, or just vectors off to never-never land.)
Now that I'm with this configuration, let's see how long I can run without a router freeze/hang.- dav0dav0Jul 03, 2022Guide
Configuration info:
- Two Win10 clients- Android phone
- 2 iPads
- 1 iPhone
- 2 TB hard drive, with separate power supply
running latest firmware on Netgear R7000P
