dav0dav0's avatar
Apr 13, 2021
R7000P crashes with Readyshare usage
Nighthawk router running fine with 2.4 and 5GHz users. Hook up 2 TB USB drive (Western Digital, nothing exotic) formatted as NTFS (probably MBR, but not sure). Basic readyshare read/write with driv...
  • dav0dav0's avatar
    dav0dav0
    Jul 16, 2022
    Well, I don't want to jinx this, but I believe all the above issues have been resolved.  I've been running for 5 days now with 100% functionality, no reboots, and a more responsive/reliable administrative app (NetGear's Genie on the PC).
    The big change: doing a factory-reset on the router and manually reconfiguring it to my needs (i.e., not doing a backup/restore of settings).
    Seems like something somewhere in the router's little mind had gotten corrupted, causing all kinds of confusion.. What may have caused this was its moving to a totally new network (when it was new, it was on one ISP...then it got moved to a new ISP without making any changes). Note that in during all my wild-goose chases I had updated the firmware, and the confusion persisted because the problem was buried somewhere in the configuration/settings data.
    So the morals of my story are:
    1. When troubleshooting, start with a factory refresh and brand new settings
    2. When moving a router across networks, see #1
