jeelder01
Aug 19, 2020Tutor
R7000P Dropping Wired Connection
Greetings, Recently my R7000P has been dropping it's hard wired connection to my cable modem. The wifi LEDs remain white, the connection LED goes orange. It requires power cycling the router to ...
- Aug 25, 2020
Maybe I missed it in this long thread.
Has the Ethernet cable every been replaced? Bad Ethernet cable end can cause issues like is described.
Aug 25, 2020Guru - Experienced User
yes
labatt
Aug 25, 2020Mentor
- jeelder01Aug 28, 2020Tutor
Update: 56 hours into replacing the ethernet cable and no dropped hardwired connections. Going to considered this solved. Thanks for the patience and help working through this problem!
