RuP
Oct 03, 2017Initiate
R7000P drops internet connections
Hi, We purchased a new R7000P a couple of weeks ago as a replacement for our old R6220 router and are now experiencing random internet/wan connection drop outs. As a reference the 6220 never ...
- Oct 09, 2017
Hi RuP,
If you connect the old router, will you still get stable connection?
Connect the computer directly to the modem and check if the connection is stable.
If still the same, reset the router and reconfigure.
JamesGL
Oct 15, 2017NETGEAR Employee Retired
Hi RuP,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
MTomasco22
Oct 20, 2017Initiate
Is the only solution to reset to factory and reconfigure? I’m having the same issue where my R7000P which is setup as WiFi router in my house drops internet twice a day. I have the R7000p setup with a WAN address of my local subnet.
- owenchenOct 20, 2017Initiate
Hi, I have same problem as well. I have 100M download speed from Comcast when connected to computer directly. But only have 50M from this router. I did rest to factory defult, but still have same issue. Appreciate if there is solution.
- JamesGLOct 26, 2017NETGEAR Employee Retired
Hi All,
What is the firmware version of the router?- owenchenOct 27, 2017Initiate
Hi, my firmware version is
V1.0.9.12_1.2.23
Is there any newer version for R7000-100PAS?
Thanks for your help.
- JamesGLNov 02, 2017NETGEAR Employee Retired
Hi owenchen,
Your device is different from the subject. This thread is for R7000P. You may create another thread for R7000.
For R7000. that is the latest firmware.
