RuP
Oct 03, 2017Initiate
R7000P drops internet connections
Hi, We purchased a new R7000P a couple of weeks ago as a replacement for our old R6220 router and are now experiencing random internet/wan connection drop outs. As a reference the 6220 never ...
- Oct 09, 2017
Hi RuP,
If you connect the old router, will you still get stable connection?
Connect the computer directly to the modem and check if the connection is stable.
If still the same, reset the router and reconfigure.
Shankarvs
Nov 25, 2017Tutor
this is very frustrating!!.. Lately my NetGear router (A900 r7000) is droping connection multiple times a day ( both wireless and wired).
I tried MANY suggestions listed above. I did factory reset, MTU adjustment, security adjustment etc.. But nothing works. and Netgear has not provided any solution.
and whats puzzling is, they want MORE money for support!
any help would be greatly appreciated
JamesGL
Nov 26, 2017NETGEAR Employee Retired
Hi Shankarvs,
What is the firmware version of the router?
What other firmwares you have tried?
