RuP
Oct 03, 2017Initiate
R7000P drops internet connections
Hi, We purchased a new R7000P a couple of weeks ago as a replacement for our old R6220 router and are now experiencing random internet/wan connection drop outs. As a reference the 6220 never ...
- Oct 09, 2017
Hi RuP,
If you connect the old router, will you still get stable connection?
Connect the computer directly to the modem and check if the connection is stable.
If still the same, reset the router and reconfigure.
jmleczko
Dec 03, 2017Guide
Same issue here.
Running V1.2.0.22_1.0.78. Tried the factory reset and security settings with no success. router drops both 2.4 and 5. To pay this price tag and deal with such poor quality, I think it's time to switch to another manufacturer.
-JM
Volstate
Dec 03, 2017Apprentice
I stated in another thread what has worked for me so far is disabling 5ghz and only running 2.4. Running both bands at same time appears to be the issue which is very frustrating because it's a DUAL BAND router. Netgear need to fix this ASAP. I haven't tried running just 5ghz it may run independently as well.
