joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
joejoeinc
Jun 13, 2019Apprentice
I can now reproduce the error buy copying a file from a wifi device to a hardwired laptop.. the hardwired laptop will remain online but the wifi PC at the other will drop off wifi and pings to it will stop responding
- joejoeincJun 13, 2019Apprentice
After talking with Netgear support today they've advised to replace the router.
- joejoeincJun 15, 2019Apprentice
After followiong netgears support recommendation to swap the router with the same model R7000P (New) I can reproduce the 'clients dropping from Wi-Fi' issues straight away on the new router just by copying files from a Wireless desktop to a Wired laptop.
As a sanity test I grabbed my old Billion router out and tested the exact same way (the Wifi is slower on the old router) using the old router I see no drop outs when copying files.
- JohnNadeauJun 16, 2019Apprentice
I had a similar problem on an R7000. Disabling the Guest Networks resolved the problem (well at least as a work-around).
Is your Guest Network enabled or disabled?
