joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
joejoeinc
Aug 05, 2019Apprentice
I don't think the router is complete garbage. I think the implementation of the MIMO function is horrible. The rest of the router seems to do mostly what it was advertised to do. The router WiFi is fast which is good. However, given the choice to buy again I would probably go with a different vendor.
The dropping devices on my router has a workaround of disabling the MIMO functions and this seems to give me stable connection (still have an open ticket with netgear about this)
GBart302
Aug 05, 2019Star
I disabled the MIMO function on the router to see if the concern resolves. We will see.
