joejoeinc
Jun 11, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 23, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
Blaubmania
Sep 11, 2019Tutor
I have bought it, last week, update fw, but same issue that wifi is dropping. I see it when i transfer large files.
I have deactivate MIMO, now wifi works correct.
Very bad support from Netgear!!! I think it was a bad choice to buy this product :(
Thank you for your workaround, without it i had to search hours to find the problem.
Blaubmania
Sep 11, 2019Tutor
Did someone have the Problem, when deactivate MIMO, the wifi speed is very slow. With MIMO 40MB/s, without 8MB/s?
- BlaubmaniaSep 11, 2019Tutor
Speed Problem, resolved after reset again the Router. What a crab...
Deactivate again MIMO, now everything works fine, no wifi drop anymore. It will be nice if Netgear fix the MIMO Problem.
