joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
monkeymagik
Oct 01, 2019Aspirant
Yep. I have exactly the same problem with the same router (R7000P). Wired connections seem stable, but every now and then wifi drops for all devices on the network. Weirdly enough if I disable wifi on one of those devices for a moment and re-enable, everything springs back to life.
I've disabled dynamic QoS, which seemed to help a bit... but it was a feature I'd like to use.
I've considered disabling Smart Wifi and/or MU-MIMO... but they're also features I'd like to keep. Particularly the Smart Wifi, other wise I would have gotten a mesh kit. It would be nice if the features on the box worked. Parental controls are handy, but also a bit buggy.
The router I got was a repack in the store... seems someone else had the same issue with the same router. If I was to return I'd get a different router (not Netgear).
joejoeinc
Oct 01, 2019Apprentice
Just try disabling the MIMO feature.. .you'll find all the other issues go away and you'll be able to use all the other features you're talking about.
