joejoeinc
Jun 11, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 23, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
w0203j
Oct 27, 2019Initiate
Will try disasbling MIMO and see what happends for a while.
srfnmnk
Jan 14, 2020Initiate
Same here. Got a new razr blade 15 and realized that every time I turned it on, I had about 10-15 minutes of wifi and then all wifi connected devices would drop. After a little research I found that the cpu i this razr blade 15 laptop, Intel Core i7-8750H, has this great new "feature". Googling around I found this post and disabled MU-MIMO, boom, problem solved.
Thank you so much for posting this and doing all the troubleshooting. So glad you were able to reproduce the issue as I was not directly other than just using my laptop for a few minutes waiting for all wireless devices to lose connection. Incredible.
P.S. I got excited when I saw that there were logs on the router...then I looked at them and realized...they were zero help.
- Capn_PratApr 01, 2020Initiate
Just incase anyone is wondering, this is apparently STILL an issue. Thank you so much for the workaround. MU-MIMO was one of the reasons I went with this router, but oh well, I guess?
- joejoeincApr 01, 2020Apprentice
Agreed MIMO still an issue. But it'll never find a solution (not with netgear). The only reason a firmware was released about 6 months ago was beause netgear broke 'Attached Devices' with a previous firmware update and then had to release a newer firmware update to fix the previously broken update. After that last update nothing at all.
I wouldn't get your hopes up of a fix for MIMO as this will be up to individual manfacturers to fix each implimentation of MIMO.
- nyclewisApr 01, 2020StarI installed the last stable build of dd-wrt and it's been 100% better. Previously had been doing the nightly betas but the unpredictable bugs got to me.
