joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
Renaldo123
Apr 13, 2020Guide
I'm also quite disappointed with this router. I bought it a couple of days ago, and I'm experiencing multiple drop out issues, and the router is literally 2 meters away from all the devices that need wifi. I've submitted a support ticket, will see what they say.
So far I've disabled all the options for the Guest Network, turned off MU-MIMO, I'm also using Smart Connect. All of these things together seem to help a little bit but devices still continue to drop out once or twice every couple of hours.
