joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
mttech1
May 01, 2020Aspirant
i am having this problem, help
Retired_Member
May 01, 2020There is no help. Get rid of that pos.
- ChriswarrenMay 04, 2020Initiate
Already threw it away! I will never buy Netgear ever again!
- Renaldo123May 04, 2020Guide
I'd like to update that after making all the changes I discussed in my last post, the router has been more stable.
However, using my previous router, the Huawei HG659 as a benchmark, I can say that I still experience the below, which I didn't experience with my previous 'cheap' router:
- device will dropout at least one a day (due to lockdowns we always have at least 2 laptops + 2 mobiles on the network), i.e. you will see the wifi disconnect and then reconnect on the laptop
- needed a restart once since I made the changes: this was a significant improvement, but with the cheap Huawei, I never had to restart it
I did however opt to connect the PS4 to an ethernet cable because we do all our streaming using the console, and I noticed that the wifi would be affected by it. This has helped a lot, it is worth noting that with the Huawei I could stream with the PS4, and all my devices would be connected without any problem.
All in all, I can say that all the changes I've done have improved the situation. If return policies in my country were generous I would've returned this product.
If you're reading this and you can still return the product, PLEASE RETURN IT. To ensure that it works you're going to have to disable a lot of features, and with those turned off, you might as well get a cheaper model or a different one altogether.
- joejoeincMay 04, 2020Apprentice
Given the choice again I would not purchase a n R7000P. What's on listed on the box doesn't actually work (looking at you MIMO). I've also found the QoS is pretty crap at managing settings and was actually slowing my internet quite substantially.
