joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
Arx8000
May 01, 2020Aspirant
I had similar issues like everyone else here, wifi would drop several times per day. The router was working just fine for a couple of years with just my phone and Chromecast, but after adding a new PC into the mix, the drops started happening. I even exchanged my laptop into a different brand as I thought it was the laptop's fault! Didn't help, same thing on the new one.
I disabled MU-MIMO (also disabled all the guest network stuff and turned QoS on) and the drops stopped, hasn't been happening anymore for a couple of days. Before it went off several times per day, every day.
I wish there was even some acknowledgement of this issue, or some reassurance that this issue is being looked into, but I guess we won't be getting it here.
(Firmware is V1.3.1.64_10.1.36, R7000P on 5GHz wifi with a smartphone, PC, Chromecast)
