joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
nyclewis
May 05, 2020Star
Before switching to DD-WRT, downgrading the firmware to v1.31.1.26 (R7000P-V1.3.1.26_10.1.3.chk) did a decent job regarding stability. This included keeping MIMO disabled.
joejoeinc
May 05, 2020Apprentice
Has anyone in here tried switching to DD-WRT on the R7000P just wondering if anyone has had any luck with it
- nyclewisMay 05, 2020Star
Running DD-WRT Firmware: DD-WRT v3.0-r40559 std (08/06/19).
Slower speed than Netgear FW, I might not one of the 5000 settings correct. But more stable.
