joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
joejoeinc
May 04, 2020Apprentice
Given the choice again I would not purchase a n R7000P. What's on listed on the box doesn't actually work (looking at you MIMO). I've also found the QoS is pretty crap at managing settings and was actually slowing my internet quite substantially.
JLundy92
May 06, 2020Aspirant
Yeah I just bought mine the other day. After about 12 hours, started dropping 5G to the internet. Tried a bunch of settings and firmware refreash. The only thing that seemed to fix it was disabling MU-MIMO. Pretty pathetic that you have to disable a main setting to make a brand new router work. By the sound of it here, Netgear does not seem to care. Probably going to take it back to Best Buy and get something else. Unacceptable Netgear!
- Renaldo123May 06, 2020Guide
JLundy92 wrote:Yeah I just bought mine the other day. After about 12 hours, started dropping 5G to the internet. Tried a bunch of settings and firmware refreash. The only thing that seemed to fix it was disabling MU-MIMO. Pretty pathetic that you have to disable a main setting to make a brand new router work. By the sound of it here, Netgear does not seem to care. Probably going to take it back to Best Buy and get something else. Unacceptable Netgear!
Get something else. All of us in this thread had to 'dumb down' our routers to get it to work. Swap it while you can!
