joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
phetamine
May 06, 2020Tutor
Found this thread after my R7000P started having the connection drop-out issue in the past 2 weeks. Like alot of people here my wife and I have both observed this happening anywhere from 2-4 times per day. Only changes to settings I made were the normal ones: login settings, wifi SSID/pw, and assigned my NAS to a static IP and that's about it - left everything else on stock settings. Didn't enable Guest network ever, etc.
Currently I'm running V1.3.1.64_10.1.36 firmware and the router seemed to be working solidly prior to this issue since it was purchased in May 2019. I turned off MI-MIMU and turning on QoS as suggested before...hopefully this will work. Not ready to throw in the towel yet!
Worst comes to worst I'll load a 3rd party firmware, probably DD-WRT. I had the R7000 before that need frequently reboots (so effing annoying) until I loaded DD-WRT onto it and presto! it became a rock solid router for years. I remember reverting it back to stock being not-so-straightforward which is why I want to avoid going down that route again.
- decker12May 10, 2020Star
I've had this router for about 8 months and just stared having the 5ghz wifi drop out issue the past three days. Nothing has changed on my network, so it's frustrating. I have disabled MU-MIMO as per the advice in this thread, so lets see if it works.
I had DD-WRT on this router but would not recommend using it if you have gigabit internet. With DD-WRT I could never get above 250mb/s which is a shame because I do like DD-WRT. Reinstalling factory firmware and I can get 800mb/s.
Unfortunately, disabling MU-MIMO did not resolve the problem for me. Just happened again on the 5ghz band a few minutes ago. Really aggravating.
- JohnNadeauMay 11, 2020Apprentice
I had an R7000 (not p) that started randomly dropping the 5ghz band after years of being very stable (I hadn't changed anything recently on the settings, nor did I change the firmware). It reminding me of overheating problems I've experienced on other routers before they failed, but I never got around to testing it as I just bought a new one.
Long story short: has anyone tried to pop the top and blow a cooling fan on the unit to see if it helped?
