joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
decker12
May 10, 2020Star
I've had this router for about 8 months and just stared having the 5ghz wifi drop out issue the past three days. Nothing has changed on my network, so it's frustrating. I have disabled MU-MIMO as per the advice in this thread, so lets see if it works.
I had DD-WRT on this router but would not recommend using it if you have gigabit internet. With DD-WRT I could never get above 250mb/s which is a shame because I do like DD-WRT. Reinstalling factory firmware and I can get 800mb/s.
decker12
May 10, 2020Star
Unfortunately, disabling MU-MIMO did not resolve the problem for me. Just happened again on the 5ghz band a few minutes ago. Really aggravating.
