joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
phetamine
May 11, 2020Tutor
Thanks for the info re: DD-WRT - you probably save me a few hours of work :)
Turning off mu-mimo + turning on QoS seemed to improve the drop out issue as I haven't experienced it since making those changes.
I was googling for a program/app/whatever to monitor my actual wifi up-time and found a simple site - just search "star trinity internet connection monitor". I'm gonna leave it running on my laptop for at least the day to make sure all is well... or not.
joejoeinc
May 11, 2020Apprentice
If you want to capture some logs to go through you can configure the R7000P to log everything it tries to do.
http://192.168.1.1/debug.htm
Replace the Ip with the IP of your router.
Just remember to turn it off once done otherwise it'll use up all the space available eventually.
- decker12May 11, 2020Star
joejoeinc Read my mind! I was going to ask in another thread how to get better/more detailed logs from the R7000P.
What is the process for using that? Is the Start Capture button ONLY for packet capture, and do you think I should use Packet Capture to determine what's going on when my 5ghz radio dies?
Or is it already generating log files just by being powered on and I just have to download them?
- joejoeincMay 11, 2020Apprentice
Open the debug URL.. configure your log settings and then hit 'start capture'. Now try to force the error/issue you are having. Then stop the capture and then download it.
- decker12May 13, 2020Star
Any idea what to look for in the log file bundle? Just happened again tonight, at 7:15 (always seems to happen at night). 5ghz radio starts to lag hard - pings to sites taking 2000ms, then dies entirely.
2.4ghz radio is fine, so I just switch over to it's SSID while troubleshooting.
Really aggravating.
