joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
joejoeinc
May 11, 2020Apprentice
Open the debug URL.. configure your log settings and then hit 'start capture'. Now try to force the error/issue you are having. Then stop the capture and then download it.
decker12
May 13, 2020Star
Any idea what to look for in the log file bundle? Just happened again tonight, at 7:15 (always seems to happen at night). 5ghz radio starts to lag hard - pings to sites taking 2000ms, then dies entirely.
2.4ghz radio is fine, so I just switch over to it's SSID while troubleshooting.
Really aggravating.
- decker12May 19, 2020Star
I bailed on the router and re-setup my older R6700V2 which has been working perfectly for the past bunch of days. Something's just plain broken with the 5ghz on this R7000 so it's useless to me. Spent $200+ on it just 8 months ago and now the thing is acting sketchy.
Sorry Netgear, you lost me as a customer. I'll use the R6700V2 until other vendors come back in-stock (stockpiles are low right now) and then swap manufacturers and let all my friends, family, and coworkers know to do the same. Ya blew it.
- MSE-6May 19, 2020Aspirant
decker12 wrote:I bailed on the router and re-setup my older R6700V2 which has been working perfectly for the past bunch of days. Something's just plain broken with the 5ghz on this R7000 so it's useless to me. Spent $200+ on it just 8 months ago and now the thing is acting sketchy.
I did the same. I even got an RMA, but I need to pay return shipping. That's just throwing good money after bad. I went with an Asus RT-AX58U. Finally a WiFi connection that works like it's supposed to. I'm really unhappy that I blew $160 on this pos R7000P.
