joejoeinc
Jun 10, 2019Apprentice
R7000P drops WIFI connections frequently
I'm finding that the r7000P frequeently drops client wifi connections. I have two PIxel 2XL's that frequently get booted off the 5GHz wifi whenever you put any demand on the router. The symptoms are...
- Jun 22, 2019
After many hours of troubleshooting, I've found that disabling the MU-MIMO function on the R7000P gives my devices a stable connection.
Advanced > Advanced Setup > Wireless Setting > [Disable MU-MIMO]. Apply.
I have been able to transfer several large files from a wifi device to a wired device without constant dropouts/disconnections at the expense of actually being able to use the MU-MIMO functions of the router.
There are either issues in the way Netgear has implemented MU-MIMO or an incompatibility issue with some other wifi devices on the network. Since I replaced the r7000P with a new one I suspect it's an issue in the Netgear router not my devices (I can't confirm this though as I don't have a different make/model MU-MIMO router to test).
Since MIMO is one of the main selling point for this router this also raises a few new questions.
phetamine
Jun 02, 2020Tutor
It's been almost 30 days since I've turned off mu-mimo and turned on QoS - so far so good (knock on wood) re: wifi connection stability. I haven't bothered with logs tho' so I can't say 100% for sure but day-to-day uptime has been pretty solid. Still this is not exactly confidence inspiring by any stretch of the imagination for this product.
The regulars over on the networking sub-reddit frequently recommend the ubiquiti amplifi line so I just might give that a try. Not exactly cheap but might be worth the extra $ since I'm so tired of spending countless hours troubleshooting.
