BruKat
May 25, 2021Aspirant
R7000P drops WIFI connections frequently
I am constantly dropping wifi connections, have to reboot router to get them back. No issues with direct internet. Any ideas? Has been an issue for few months now, like to try fix it before going wi...
BruKat
I have V1.3.2.134_10.1.66 currently and re installed it to no avail.
May 25, 2021Guru - Experienced User
Is it only wifi dropping?
do wired devices drop?
Did you try a factory reset?
- BruKatMay 25, 2021Aspirant
Only wifi drops, hard wired stays on
have not tried factory reset yet
- plemansMay 25, 2021Guru - Experienced User
Whenever theres an issue after a firmware change (might have auto-upgraded) a factory reset and new install (not using a backup configuration) is the first thing I try.
